Powered for the enterprise, the HP EliteDesk 705 SFF is one of our most secure PCs that delivers impressive value with the performance required by today's high-productivity workforce in a new space-saving and stylish design.
Power through your day with Windows 10 Pro with built-in security, collaboration, and connectivity.
Firmware level protection
Protect the firmware that antivirus can't reach! The hardware-enforced self-healing protection offered by HP Sure Start Gen4 automatically recovers the BIOS from malware, rootkits, or corruption.
Protect critical security processes
Keep your critical processes running, even if malware tries to shut them down. HP Sure Run extends hardware enforced self-healing protection into the operating system to guard against malicious attacks on applications and processes.
Browse confidently
Help protect your PC from websites, attachments, malware, ransomware, and viruses with hardware-enforced security from HP Sure Click.
Quick and secure recovery to the latest image
Quickly and securely restore PCs to the latest image using a network connection with optional HP Sure Recover.
Get PC images right the first time
ITDMs can quickly help create, improve, and secure custom Windows images with HP Image Assistant Gen3.
HP EliteDesk 705 G4 - SFF Ryzen 3 Pro 2200G 3.5 GHz - 8 GB - SSD 256 GB - UK
Personal computer - SFF
AMD Ryzen 3 Pro 2200G / 3.5 GHz (up to 3.7 GHz, (Quad-Core)
6 x USB 2.0 (2 front, 4 rear) (two of them with wake functionality, one of them is fast-charging) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x USB-C 3.0 (1 in front) , 2 x DisplayPort , 1 x VGA , 1 x headphones/microphone (1 in front) , 1 x audio line-out , 1 x audio line-in , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE, Common Criteria EAL4+, low halogen
Power supply
Power Provided
180 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
92%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Limited warranty - parts and labour - 3 years - on-site
