Beauty runs deep on HP's thinnest enterprise-class 35,56 cm (14") diagonal Ultrabook packed with impressive performance, security, and manageability features to help bring out your finest work.
Collaborate with colleagues using a 720p webcam and noise-canceling DTS Studio Sound.
Easy connections
Essential ports provide convenient connections to peripheral devices. The DisplayPort allows fast connections to monitors and projectors, while USB 3.0 charging ports on either side of the machine allow for hassle free charging of mobile devices.
Adapt to your work style
Help boost efficiency with optional accessories like the Ultraslim Docking Station, Elite Displays, and small AC Travel adapter to match your personal work style.
Road ready
Never fear accidental bumps on the durable HP EliteBook 1040.
Customized protection
HP BIOSphere keeps mission-critical data and systems protected with customizable security.
Self-healing safeguard
HP Sure Start detects corruption and self-heals the BIOS.
Limited warranty - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
CPU
Intel Core i5 (5th Gen) 5200U / 2.2 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
L3 - 3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (provided memory is soldered)
Max RAM Supported
8 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
128 GB SSD M.2 SATA 6Gb/s
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1600 x 900 (HD+)
Widescreen
Image Aspect Ratio
16:9
HD+ standard-viewing angle (SVA) anti-glare
Audio & Video
Graphics Processor
Intel HD Graphics 5500
Camera
Yes - 1280 x 720
Camera Features
720p HD movie recording
Sound
Stereo speakers, stereo microphone
High Definition Audio, DTS Studio Sound
Input
Keyboard, ForcePad
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad
Communications
Wireless
Bluetooth 4.0, 802.11a/b/g/n/ac, NFC
Wireless Controller
Intel Dual Band Wireless-AC 7265
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
6-cell lithium polymer
42 Wh
AC Adapter
Input
Output
45 Watt
Connections & Expansion
DisplayPort , 2 x USB 3.0 , Dock , Headphone/microphone combo jack , VGA (on supplied cable) , LAN (on supplied cable)
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Cyberlink PowerDVD, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Setup, HP Hotkey Support, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Wallpaper, HP Spare Key, HP Exclusive, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP Security Manager, Box.net 50GB storage, HP Disk Sanitizer, HP Ceement, HP Manageability, HP BIOSphere, HP Software Setup, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM, HP Device Access Manager
Intel Active Management Technology (iAMT), HP DuraFinish, HP DuraKeys, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security, 2 x USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, HP Dock Connector to Ethernet/VGA Adapter
ACPI
Localization
33.8 cm x 23.35 cm x 1.59 cm
1.51 kg
Sustainability Information
ENERGY STAR Certified
