The HP EliteBook 820 comes equipped with all of the features you need to get your business tasks completed to the highest of standards. With a proven record for solid, reliable performance, the HP 820 also comes with robust management and security features to give you extra peace of mind.
Take advantage of the SmartCard reader and Trusted Platform Module security chip to keep your laptop under lock and key when you’re not around.
With impressive battery life and weighing just 1.34kg, you’ll find the EliteBook 820 the ideal portable companion – perfect if you travel a lot for work or need to work remotely often.
Its 12.5-inch LED backlight display comes in Full HD so you can enjoy crystal clear images, while the stereo speakers provide high definition audio – handy if you’re using the integrated webcam for a business call.
With 8GB RAM and 256GB solid state drive, there’s plenty of room to store even the largest of files and documents without compromising on speed and performance.
