Designed for the modern mobile professional, the HP EliteBook 745 delivers enterprise-grade security and manageability along with powerful collaboration features to keep you connected.
Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP.
Pure performance
Take on your work with an efficiently powerful, highly secure, and reliable 2nd Gen AMD Ryzen PRO processor with Radeon VEGA graphics designed for a highly responsive experience that helps secure your data, device, and identity.
HP Sure Sense
Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
Fast and efficient wireless LAN
Get gigabit speed Wi-Fi with Wi-Fi 6 (802.11ax).
Protect critical security processes
To get control of your PC, attackers first need to take down its defenses. Keep critical security protections up and running and prevent unwanted changes to security settings with HP Sure Run Gen2, which provides resilience against attacks.
Recovery simplified
Advanced malware attacks can destroy your OS and disrupt your business. HP Sure Recover Gen2 ensures fast, secure, and automated recovery of your OS with only a network connection, so you can minimize downtime and get back to business fast.
HP EliteBook 745 G6 Notebook - 14" - AMD Ryzen 7 Pro 3700U - 8 GB RAM - 256 GB SSD - UK
Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
Wireless
Bluetooth 5.0, 802.11a/b/g/n/ac/ax
Wireless Controller
Intel Wi-Fi 6 AX 200
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Dual stream (2x2)
3-cell Lithium Ion
50 Wh
AC Adapter
Input
Output
65 Watt
Connections & Expansion
USB-C (charging) , USB 3.1 Gen 1 (charging) , Headphone/microphone combo jack , LAN , Dock , HDMI , USB 3.1 Gen 1
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Velocity, HP Secure Erase, HP Drive Packs (free download), HP Client Catalog, HP BIOS Config Utility, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, HP JetAdvantage, HP BIOSphere Gen4, HP Client Security Suite Gen4, HP Manageability & Integration Kit Gen2 (free download)
Power-on password, Setup Password, Automatic DriveLock, HP DriveLock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security, HP Sure Start Gen 4, HP Wireless Wakeup, BIOS Update via Network
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
