Staying connected while you’re on the move is easy with the HP EliteBook 725. Enjoy speedy 802.11ac wireless technology and fast data transfer from the Bluetooth 4.0.
Weighing just 1.26kg and measuring 31cm x 21.89cm x 1.89cm, this EliteBook is thin and lightweight making it the ideal machine for working on the go.
Enjoy performance without compromising on speed thanks to the powerful AMD A series processor and AMD Radeon R6 graphics card.
Keep your sensitive information secure when you’re away from your notebook by implementing the security features. Choose from SmartCard reader or Trusted Platform Module security chip for the ultimate peace of mind.
The HP 725 also offers HD resolution on its 12.5-inch display for vivid image clarity – helpful when you’re making use of the integrated webcam or editing images.
And with three years’ warranty, you can ensure long-lasting performance from HP’s proven technology.
Slim new design with all the right ports
Connect with all of the essential ports you need without the hassle of dongles - in an ultra-slim design. At just 18.9 mm, the HP EliteBook 725 comes with VGA, Display Port, RJ-45 and enterprise docking capabilities.
Strong security, powerful manageability
Protect, detect, and recover from malicious attacks with HP Sure Start - the industry’s first self-healing BIOS. Keep your team up and running with HP Touchpoint Manager and DASH manageability to help monitor the HP EliteBook 725.
Designed for collaboration
Replace your speaker phone with the HP EliteBook 725 with Audio by Bang & Olufsen that provides a rich collaboration experience for applications like Skype for Business.
Great features and value, from HP!
The ultrathin HP EliteBook 725 delivers tremendous value. HP is the first to offer the new high-performance AMD PRO A12 APU, the first commercial APU with integrated Radeon™ R7 graphics that help harness the full potential of your applications.
Key Features
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light touch optional HP EliteBook 725.
Self-healing safeguard
HP Sure Start detects attacks, corruption and self-heals the BIOS automatically.
Give your fingers a break
Keep focused without the distraction of a noisy keyboard using the HP Premium Keyboard engineered for comfort.
Field ready
Stand up to the workload with an EliteBook that passed MIL-STD 810G testing.
In-house serviceability
Easily expand your system’s serviceable components.
Give your speakers a boost
Help make good speakers sound great with HP Clear Sound Amp.
Cut out the chatter
Help suppress ambient noise including keyboard clicks with HP Noise Reduction Software.
AMD Vivid Color Technology
Experience the brilliant color saturation that makes images come to life with AMD Vivid Color Technology.
