The thin and light design with optional FHD touch display makes the HP EliteBook 700 series ideal for professionals in and out of the office. Work proficiently and confidently with HP technology and AMD PRO A-Series APUs.
The HP EliteBook 725 G2 delivers future-ready performance at an exceptional price. Featuring AMD PRO A-Series APUs now with revolutionary HSA technology, a lightweight design, and an optional FHD touch display that allows you to navigate easily and get work done.
Field ready
Never fear bumps and minor spills. The thin and light HP EliteBook 725 G2 endures HP's Total Test Process and is designed to undergo MIL-SPEC 810G testing.
Self-healing safeguard
HP Sure Start is the way to help ensure a proper boot-up thanks to corruption detection, a self-healing BIOS, and recovery that restarts where it left off if the update stalls, fails, or is corrupted.
Featuring
The latest AMD A-Series Pro APUs with HSA technology help unlock true business computing and deliver outstanding total cost of ownership, optimal manageability, and security features. Simply put, AMD A-Series PRO APUs are easy to support with the power to perform.Each HP EliteBook 725 G2 works with HP Client Management Solutions and DASH support.Rely on stable and consistent images, managed lifecycle transitions and Elite support.HP BIOSphere keeps mission-critical data and systems protected with customizable security.
3 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Drivers & Utilities, Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP ProtectTools with Credential Manager, HP Recovery Manager, HP Connection Manager, HP ePrint, HP Hotkey Support, Drive Encryption for HP ProtectTools, Password Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP File Sanitizer
HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DisplaySafe, HP BIOS Protection, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, HP Roaming Alert, 1 USB 3.0 charging port
