The premium design of the beautifully compact and durable HP EliteBook 1030 delivers style and substance. The amazing near edge-to-edge screen makes it a great travel companion that's fully equipped with HP's leading security and manageability solutions.
See more, carry less
Get big screen views from the compact and sophisticated design of the HP EliteBook 1030 with its near edge-to-edge 33,8 cm (13.3') diagonal screen and the diamond-cut all metal design.
The strong, quiet type
Work comfortably and without distraction. Focus on task at hand, the HP EliteBook 1030 runs quietly and stays cool with no fans or spinning drives.
Innovative security and manageability only from HP
Help reduce costly downtime using innovative BIOS protection from HP Sure Start with Dynamic Protection and manage devices easily with optional Intel® vPro™, HP Touch Manager or LANDesk management that integrates with advanced IT environments.
Connect and collaborate in style
Collaborate with colleagues using the HD Webcam and HP Noise Reduction Software that greatly reduces background noise. Clearly hear presenters on expertly tuned speakers with Audio by Bang & Olufsen powered up with the HP Clear Sound Amp.
