Maximize your HP Elite x3's productivity with the HP Elite x3 Passive Stylus, which allows you to write naturally on the screen and navigate touchscreen activities.
Use the two-sided stylus to write onscreen, or interact with your virtual keyboard and touch applications. The top foam tip mimics your fingertip, and the 2 mm bottom tip helps ensure accurate, smooth handwriting.
Take it with you
Attach the stylus to the included lanyard for easy carrying.
