The HP Elite x3 is HP’s newest mobile device, carefully designed to combine PC power and productivity, tablet portability, and smartphone connectivity all in one handheld device.
Enhance productivity and mobility in the workplace with the Elite x3 and Windows Continuum1. Users can effortlessly switch between a handheld phablet, and a desktop PC or laptop experience when they dock to a larger display.
Experience the power and productivity of a PC, the portability of a tablet, and the connectivity of a smartphone in the palm of your hand with the HP Elite x3, HP's first built for business 3-in-1 device. It's designed to deliver simple and seamless access to your people, apps, and data.
The handheld HP Elite x3 is an easy and convenient way to work, in the office and on the go. Start a task on the go and finish at your desk without saving, syncing or restarting with the HP Elite x3, Microsoft Continuum, and optional docks, which allow you to work with a larger display. Crafted for business users, the HP Elite x3 is a robust device with powerful processing power, a long-life battery, dual biometric scanners, and dual SIM card slots. With HP Workspace, virtualize the business critical Windows x64 and x86 apps you rely on to get the job done.
- Built for business
- Enterprise security to reinvent the way you work
- A stellar multimedia experience
- The new mobile revolution
