Enjoy the benefits of both tablet and Ultrabook when you invest in the HP Elite 1011. This handy portable device comes with all the management and security features you need for working on the move.
Thanks to its touchscreen you can use the HP Elite as a tablet for easy computing on the move and simply connect to the keyboard dock if you need to type documents.
Weighing just 1.54kg, it’s the ideal portable companion for when you need to work on the go. Enjoy speedy internet access with the 802.11n technology, helping you to work efficiently and smartly.
The 11.6-inch display offers HD resolution while the powerful Intel graphics and high definition audio ensures you get the most out of the integrated webcam. With low light enhancement, you’ll also benefit from Full HD video recording.
Connect your HP Ultrabook to a docking station when you’re in the office to allow you to continue working on the same files. Need a bigger screen? Simply connect it up to your desktop monitor, and stay in control of your sensitive documents with the SmartCard reader security feature.
