Work comfortably and stay focused with the optimized ergonomics and Full HD resolution of the HP E27 G4 FHD Monitor with HP Eye Ease that is designed around you. Make life easy for IT with remote manageability.
Connect to your most frequently-used devices with VGA, HDMI, and DisplayPort . Add up to four of your USB accessories right at the monitor with the integrated USB 3.2 hub.
Find your comfort zone
Work comfortably with adjustable tilt, height, and swivel settings. Use pivot rotation to conveniently customize portrait or landscape views on multiple monitors.
Responsibly made
Energy efficiency is built into every ENERGY STAR certified, EPEAT 2020 registered, and low halogen display. We go one step further with 100% recyclable packaging that's easily accepted by recycling facilities.
Take your PC off the desk
Create an efficient, compact, solution when you mount your HP Desktop Mini PC directly on the column stand using the optional HP B300 PC Mounting Bracket.
Personalize and help protect your monitor
Customize your monitor and help deter its theft with easy, intuitive HP Display Center software that lets you tailor your settings, partition screens, and even dim the screen if your monitor is disconnected without approval-all through the host PC.
Complete the picture
Customize a total solution with options5 like the HP S101 Speaker Bar, which attaches easily to the lower bezel to add stereo audio on the monitor.
HP E27 G4 - E-Series - LED monitor - Full HD (1080p) - 27"
