Go big or go home with the HP DreamColor Z32x 80,01 cm (31.5") UHD Display, HP's largest UHD 4K display, which delivers a staggering 8 million pixels and 4K resolution and has award- winning HP DreamColor technology built right in.
Explore your creativity with 8 million pixels and 4K resolution-four times that of a traditional Full HD display-on an extra-large 80,01 cm (31.5") diagonal screen.
Color as only HP DreamColor can do it
Get exceptional, consistent 10-bit color precision and out-of-the-box, color-calibrated sRGB, BT709, and Adobe RGB coverage from HP DreamColor technology. Use the HP DreamColor Calibration Kit or your choice of tool for precise color adjustments.
Boost your productivity
Connect to an array of your everyday devices right at the display with HDMI, mDP, DP, MHL, and a USB 3.0 hub with a fast-charging port. View up to four simultaneous feeds with picture-in-picture or picture-by-picture.
HP DreamColor Z32x Professional - LED monitor - 31.5"
Picture in picture, picture by picture, HDCP, DreamColor, Mobile High-Definition Link (MHL), Mercury free, arsenic-free glass
73.71 cm x 24.55 cm x 61.38 cm - with stand
10.8 kg
MHL / HDMI (HDCP) , HDMI (HDCP) , DisplayPort (HDCP) , Mini DisplayPort , 4 x USB 3.0 downstream , Audio line-out , USB 3.0 upstream
Mechanical
Display Position Adjustments
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
Security lock slot (cable lock sold separately), 1 USB 3.0 fast charging port
1 x DisplayPort cable , 1 x Mini DisplayPort cable , 1 x USB cable
Compatible with Windows 7
With stand - width: 73.71 cm - depth: 24.55 cm - height: 61.38 cm - weight: 10.8 kg , Without stand - width: 73.71 cm - depth: 7.01 cm - height: 43.46 cm - weight: 7.8 kg
