Print, scan and copy everyday documents with this simple and affordable HP Deskjet all-in-one. Save space with a compact design that fits anywhere and get started in no time with quick and easy setup.
Enjoy real versatility – produce everything you need with this no-fuss all-in-one.Do it all from one affordable device – print web pages, scan photos, copy correspondence and more.Print and copy with laser-quality text and vivid colour graphics using affordable HP ink cartridges.Get up to 2.5x more black printed pages and 2x more colour printed pages with optional high-capacity ink cartridges.
Get started straightaway with quick, easy set-up and intuitive operation
No waiting – installs right out of the box in just a few minutes.Print, scan and copy with an all-in-one designed for simple operation – just four buttons.Get performance you can rely on with HP Deskjet – the world's No.1 printer brand.Start even faster on HP PCs running Windows 8.
Save space with a sleek, stylish and compact design
Save valuable space with a compact all-in-one that's designed fit almost anywhere.Keep it close to hand on your desk, or neatly out of the way on a shelf.Conserve energy – and save money – with this ENERGY STAR qualified printer.
HP Deskjet 1510 All-in-One - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
1000 pages
Recommended Monthly Volume
300 - 400 pages
Max Copying Speed
Up to 4.5 ppm (mono) / up to 3 ppm (colour)
Max Copying Resolution
Up to 600 x 300 dpi (mono) / up to 600 x 300 dpi (colour)
Max Printing Speed
Up to 7 ppm (mono) / up to 4 ppm (colour)
Max Printing Resolution
Up to 600 x 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Original Size
216 x 297 mm (max)
Media Size
89 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, greeting cards, photo paper
Standard Media Capacity
60 sheets
Output Trays Capacity
25 sheets
Connection Availability
USB 2.0
AC 110/230 V (50/60Hz)
42.523 cm x 30.582 cm x 15.66 cm
3.6 kg
Environmental Standards
EPEAT Bronze, ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
1000 pages
300 - 400 pages
USB 2.0
Copying
Max Copying Speed
Maximum Copies
9
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
First Print Out Time B/W
17 sec
First Print Out Time Colour
24 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Max Original Size
216 x 297 mm
Min Media Size
89 x 127 mm
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 101.6 x 152.4 mm, 89 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215 x 279 mm
Printing: up to 7 ppm - B/W (ISO) , Printing: up to 4 ppm - colour (ISO) , Printing: up to 20 ppm - B/W draft , Printing: up to 16 ppm - colour draft , Copying: up to 4 ppm - B/W draft , Copying: up to 2 ppm - colour draft , Copying: up to 4.5 ppm - B/W (ISO) , Copying: up to 3 ppm - colour (ISO)
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8
Software Included
Drivers & Utilities
10 watt
Power Consumption Standby
2 watt
Power Consumption Sleep
0.9 watt
CISPR 24, CISPR 22, IEC 60950-1, FCC CFR47 Part 15 B, LVD, EN 61000-3-3:2008, ICES-003 issue 4 Class B, NOM-019-SCFI-1993 IRAM, EN 61000-3-2:2006+A1:2009+A2:2009
