So easy and intuitive, you'll love using it.
Print to any HP Designjet printer without installing any
drivers thanks to free HP ePrint & Share1.
Save time with accurate page previews, and discover the
power of touch through its colour touchscreen that
enables easy printing.
Secure your investment: this HP ePrinter is
Web-connected and easy to update. Software updates
occur automatically, every six months.
Create a print-ready PDF2 file at the same time you print
with HP ePrint & Share1.
Print high-quality results at fast speeds.
Achieve high-quality results: the 6-ink system has matte
and photo black, and grey to produce true neutral greys
and a wide range of vivid colours on plain and glossy
media.
Produce fine detailed lines with 0.02 mm minimum line
width3, and highly accurate drawings with innovative
printhead technology and Original HP inks.
Get the job done quickly without sacrificing quality: print
up to 2 A1 prints per minute in Economode.
Print complex files as easily as simple ones with 8 GB
virtual memory4.
1 HP ePrint & Share is a free Web-printing solution that lets you automatically manage content online. It requires an Internet connection. Download ePrint & Share:
www.hp.com/go/eprintandshare
2 Requires AutoCAD plug-in.
3 Using HP-GL/2.
4 Based on 640 MB RAM.
