Improve productivity with the fastest MFP on the market for all your black-and-white and colour needs. Enjoy unattended operation at costs rivaling similar black-and-white LED MFPs. This MFP is built for rigorous IT demands and top security.
All your workflow needs in a high-productivity MFP
Be the fastest – print A1-size pages in 21 seconds with dark blacks, neutral greys, and vivid colours.
Print out your first page right away thanks to ultra-fast processing and zero warm-up time.
Copy and scan quickly with advanced features and efficient workflow tools – presets, batch scanning, multipage PDFs, and scan to email.
Stay organised and avoid clutter – the integrated 100-page stacker delivers prints and copies neatly collated.
A production printer for unattended, low-cost use
Print your black-and-white drawings at the same cost per page as comparable black-and-white LED MFPs.
Operate unattended thanks to two heavy rolls of up to 200 m (650 ft) and a total ink capacity of 1800 ml.
Built for high-volume printing – rely on a robust design to fulfil the most demanding jobs.
Manage projects and control costs effectively, using embedded professional accounting features.
Built for rigorous IT demands and top security
Minimise device-management tasks and costs, using the HP DesignJet Universal Print Driver.
Manage your fleet with ease, while saving time and helping to reduce costs, thanks to HP Web Jetadmin.
Protect and manage confidential jobs securely – retrieve documents at the printer with a personal PIN.
Safeguard confidential information, using a self-encrypting HDD with AES-256, Secure Disk Erase, and IPsec.
