Take advantage of an integrated scanning, copying and printing experience. Enhance your productivity with fast, right-click printing and high-quality colour for all your jobs - from fine lines to photographs and everything in between.
Manage large-format documents from scan through print or archive with this reliable MFP.Operation is intuitive and simple with a full-station 38.1 cm (15-inch) touch screen display, which also includes a virtual keyboard.Perform scan, copy and print functions with greater control and confidence.
Do more with one device and see your productivity soar
Save time and paper with 2 online rolls and smart switching, so you can handle CAD and GIS projects at the same time.You're back to business in no time with this HP MFP that scans, copies, and prints your projects quickly.Batch scanning and printing is fast and easy thanks to free HP Instant Printing and collating features.
See top quality results across a broad range of applications from any original
Get a high level of quality in line drawings, maps and posters with 4 camera CCD scanning technology with 600 dpi.Experience added versatility when you scan and print AEC, CAD, and GIS documents.Produce fine lines, crisp text, and vivid colour with Original HP inks, including 2 blacks and a grey ink.Transform your everyday printing using HP everyday bond papers with ColorPRO Technology.
HP DesignJet T1200 HD-MFP - multifunction printer - colour
44" multifunction printer
English, German, French, Italian, Spanish / Europe
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 6-ink
Max Copying Resolution
9600 dpi (colour)
Max Printing Speed
Up to 0.47 min/page (mono) / up to 41 sq.m/hour (colour)
Max Printing Resolution
Up to 2400 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Display
15"
Original Size
1067 mm width (max)
Media Size
Roll (111.8 cm x 91 m) (max)
Media Type
Coated paper, bond paper, film, vellum paper, glossy photo paper, matte photo paper, satin photo paper
Standard Media Capacity
2 rolls
Connection Availability
USB 2.0, Gigabit LAN, IEEE-1394 (Firewire)
Office Machine Features
EIO slot, automatic cutter
AC 120/230 V (50/60Hz)
190 cm x 100 cm x 160 cm
200 kg
Printing Technology
Ink-jet - colour
Display Diagonal Size
15"
Display Features
Touch screen
Hard Disk Drive
320 GB
Copying
9600 dpi (colour)
Max Document Enlargement
10000%
Max Document Reduction
1%
Maximum Copies
1000
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A0 (841 x 1189 mm), ANSI B (Ledger) (279 x 432 mm), ANSI C (432 x 559 mm), ANSI E (864 x 1118 mm), ANSI D (559 x 864 mm), Roll (111.8 cm x 91 m), 210 x 279 mm, 1118 x 1676 mm
2 rolls
Input tray - 2 rolls - Roll (111.8 cm x 91 m) weight: 60 g/m² - 328 g/m²
Speed Details
Printing: 28 sec (A1) - B/W draft , Printing: 28 sec (D) - B/W draft , Printing: up to 41 sq.m/hour - colour draft , Scanning: up to 51 mm/sec - colour , Scanning: up to 152 mm/sec - B/W
2 x Gigabit LAN - RJ-45 , 2 x USB 2.0 , 1 x FireWire
Operating System Support
MS Windows XP SP2 or later, Apple Mac OS X 10.4, Apple Mac OS X 10.5, Apple Mac OS X 10.6, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits)
Software Included
Drivers & Utilities
300 Watt
Power Consumption Standby
65.3 Watt
Power Consumption Sleep
7 Watt
USB cable, stand, Ethernet cable, Firewire cable, spindle
FCC Class A certified, CSA, VCCI, GOST, VCCI Class A ITE, PSB, MOC, IRAM, RoHS, EN 60950-1, WEEE, ACA, REACH, BSMI Class A, ICES Class A, KCC Class A, LVD, EMC Class A, CCC Class A
