Solid PC performance. The HP Compaq Pro 6300 Small Form Factor is a versatile and powerful PC featuring customizable security and expansion features to help your business excel.
Give performance a boost with the new, Intel Q75 Express chipset and the power of a 3rd generation Intel Core processor family. Get the most out of graphic-intensive applications with integrated Intel HD Graphics.Take advantage of customizable expansion options with PCI and PCI Express slots to support a variety of accessory cards. Transfer data with noticeable speed through the new USB 3.0 ports.Configure the system memory with up to 32GB of DDR3-1600 SDRAM. Multiple storage drive configurations can double your storage space or provide a convenient back-up solution.Improve productivity with independent dual monitor support. With an optional discrete graphics card, the HP Compaq Pro 6300 Small Form Factor can support up to four independent displays.Access major components with the tool-less hood removal, tool-less drive bays and slots. Upgrade components in a snap with quick release latches, green pull tabs and color coordinated cables and connectors inside PC.
Simplified management
Protect your business-sensitive data with HP's certified and embedded Trusted Platform Module (TPM). Disable USB ports and slots for added security.HP BIOS and Intel Standard Manageability help control your PC fleet with features for easy management and trouble shooting.A minimum of 15 months of platform stability enables long-range planning, maintains a consistent work environment and helps minimize support costs.Rely on world-class service and support with a standard, 3-year limited warranty from HP. Additional coverage is available through HP Care Pack Services.
Save energy, reduce impact
Help lower your operational costs and overall eco-footprint with an HP business PC that's ENERGY STAR qualified, EPEAT Gold registered and designed with low halogen materials.Easily optimize and maintain your PC's power settings with HP Power Assistant software, enabling you to set up custom schedules for when the machine goes into low power states.
HP Compaq 6300 Pro - SFF - Core i5 3470 3.2 GHz - 4 GB - HDD 500 GB
Personal computer - small form factor - system password, power-on password, serial port I/O control, USB port control, DriveLock
Intel Core i5 (3rd Gen) 3470 / 3.2 GHz (, up to 3.6 GHz, (Quad-Core)
Intel HD Graphics 2500 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
1GbE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Adobe Flash Player, HP Help and Support, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, PDF Complete Corporate Edition, WinZip Basic, HP Marketplace, HP Wallpaper, Microsoft Advantage Program
1 (total) / 0 (free) x external 5.25" , 1 (total) / 0 (free) x external 3.5" , 1 (total) / 0 (free) x internal 3.5"
Slots
1 (total) / 1 (free) x PCI - low-profile , 2 (total) / 2 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 0 (free) x CPU , 4 DIMM 240-pin
6 x USB 2.0 (4 front, 2 rear) , 1 x serial , 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x VGA , 1 x DisplayPort , 1 x audio line-in/microphone (1 in front) , 1 x audio line-out/headphones (1 in front) , 1 x audio line-out , 1 x audio line-in , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0
System password, power-on password, serial port I/O control, USB port control, DriveLock
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
Manufacturer Selling Program
HP Smart Buy
Power supply
Power Provided
240 Watt
Efficiency
90%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
OS Certified
Red Hat Enterprise Linux, SUSE Linux Enterprise Desktop 11
Software
