Set up and start printing fast with an easy-to-use, intuitive control panel.Speed through document tasks: get the first print out in a matter of seconds. Set the pace for success with an MFP that prints, copies and scans fast.
Easily copy both sides of a two-sided ID or other small document onto the front of a single-page.Help save energy with HP Auto-On/Auto-Off Technology – intelligence that can turn your printer on when you need it and off when you don't.
Print from virtually anywhere with HP ePrint and Apple AirPrint .Share printing resources with an Ethernet network.Easily connect the MFP directly to a PC via the included Hi-speed USB 2.0 port.
- HP Color LaserJet Pro MFP M176n - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 250 - 950 pages
- Max Copying Speed
- Up to 16 ppm (mono) / up to 4 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 2400 dpi (mono) / up to 2400 dpi (colour)
- Scanning
- 1200 x 1200 dpi
- Original Size
- 216 x 297 mm (max)
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, film, glossy paper
- Standard Media Capacity
- 150 sheets
- Max Media Capacity
- 150 sheets
- Output Trays Capacity
- 50 sheets
- Connection Availability
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to folder, scan to application
- Power
- AC 230 V (50/60Hz)
- 42.3 cm x 42.5 cm x 28 cm
- 15 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Laser - colour
- 20000 pages
- 250 - 950 pages
- Display
- 2 lines x 16 characters
- Interface
- USB 2.0, LAN
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB
- Max Supported Memory
- 128 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCLm, PCLms
- Image Enhancement Technology
- HP ImageREt 2400
- First Print Out Time B/W
- 16 sec
- First Print Out Time Colour
- 27.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 101.6 x 152.4 mm, 76 x 127 mm, 215.9 x 330.2 mm, 127 x 203.2 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 150 sheets
- 50 sheets
- Input tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Output tray - 50 sheets
- Speed Details
- Printing: up to 17 ppm (Letter A) - B/W normal , Printing: up to 4 ppm (Letter A) - colour normal , Printing: up to 16 ppm (A4) - B/W normal , Printing: up to 4 ppm (A4) - colour normal , Copying: up to 17 ppm (Letter A) - B/W normal , Copying: up to 4 ppm (Letter A) - colour normal , Copying: up to 16 ppm (A4) - B/W normal , Copying: up to 4 ppm - colour normal , Scanning: up to 7.5 ipm - B/W , Scanning: up to 5.5 ipm - colour
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x LAN - RJ-45
- Operating System Support
- Linux, MS Windows Server 2008 x64 Edition, MS Windows XP SP2 or later, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.6.8 or later, MS Windows Server 2003 SP1 or later, MS Windows XP 64-bit Edition SP2 or later, MS Windows Server 2012, Windows 8, Windows 8 64-bit, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2003 x64 Edition SP1 or later, MS Windows Server 2008 Enterprise, MS Windows Server 2008 Standard
- Software Included
- Drivers & Utilities, Readiris, HP LaserJet Scan
- Voltage Required
- 300 watt
- Power Consumption Standby
- 8.3 watt
- Power Consumption Sleep
- 1 watt
- Consumables Included
- 1 x toner cartridge (black) - up to 500 pages , 1 x toner cartridge (cyan) - up to 500 pages , 1 x toner cartridge (magenta) - up to 500 pages , 1 x toner cartridge (yellow) - up to 500 pages
- FCC Class B certified, UL, cUL, GS, ICES-003, CISPR 22, EN55022 Class B, EMC, Laser Class 1, FCC CFR47 Part 15, IEC 60950-1, EN 60825-1, GB 17625.1, LVD, GB 9254-2008, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 60825-1:2007, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- ENERGY STAR Certified
- 42.3 cm
- 42.5 cm
- 28 cm
- 15 kg
- Shipping Width
- 59.8 cm
- Shipping Depth
- 39.8 cm
- Shipping Height
- 40.9 cm
- Shipping Weight
- 18.2 kg
- Sound Emission
- 49 dBA (operating)
- 15 °C
- 30 °C
- 10 - 80%
