PC Connection Gigabit LAN, USB 2.0 host, USB 2.0, USB 2.0 host (internal)
Printing Output Type Colour
Type of Machine Fax / copier / printer / scanner
- Intuitive 8-inch (20.3 cm) HP Easy Select pivoting color touchscreen control panel
- 200-sheet automatic document feeder with single pass two-sided scanning, and HP EveryPage with ultrasonic double-feed detection
- Home button (returns to home screen)
- Plate glass color scanner handles sizes up to 11 x 17 in/A3
- Easy-access USB port to save and print files directly
- Hardware integration pocket for solution integration
- 500-sheet output bin
- Front door provides convenient access to HP toner cartridges and drums
- Built-in automatic two-sided printing
- Retractable keyboard for easy, accurate data entry
- 100-sheet multipurpose tray handles heavy custom media up to 58 lb bond
- Right-side doors provide access to the fuser and for clearing jams
- 500-sheet input tray supports media up to size 11 x 17 in/A3
- 3,500-sheet high-capacity input tray supports media sizes letter/A4
- HP Jetdirect Gigabit Ethernet print server
- HP high-performance secure hard disk
- Access port for optional Kensington-style lock
- Hi-Speed USB 2.0 port (for connecting third-party devices)
- Hi-Speed USB 2.0 printing port
- 800 MHz processor, 2.5 GB (system memory)
- Foreign interface harness (for connecting external devices)
- Two internal host USB 2.0 type ports for third party solutions
- RJ-11 fax port
