Tackle high-volume jobs with this high-performance colour MFP. Print and copy, plus scan and fax. Enhanced scanning features and a 20cm (8-inch) colour touchscreen smooth workflows. Mobile printing options help you stay productive on the go.
Get more done much faster: scan two-sided documents in a single pass ÔÇô no missed pages, no flipping pages by hand.Preview and edit scans, adjust images, and launch standard processes, all at the 20 cm (8-inch) colour touchscreen.Fast, accurate input: enter data more quickly and accurately, using the pull-out keyboard.Scan and send digital files directly to email, SharePoint , network folders or the cloud.
Mobilise business printing
Print without wires or a network. Get easy access to the MFP through optional wireless direct printing.Mobile printing at a touch: enable touch-to-print convenience from mobile devices.Easily print from smartphones, tablets, and notebooks at work, home, or on the go with Apple AirPrint and HP ePrint; Mopria-certified.Pull print jobs from your pocket ÔÇô walk up and print or scan from your USB drive.
Easily upgrade and add new capabilities as your needs change
Secure your investment ÔÇô depend on an MFP that can expand with your business, whenever solutions advance.Keep a close watch, even from afar ÔÇô centrally monitor and control your MFPs with HP Web Jetadmin.Be confident that sensitive business data is protected with advanced security and an encrypted hard disk.
Power up your productivity
Tackle high volume printing: load the MFP with up to 3,100 sheets and high-capacity Original HP cartridges, and let it go to work.Reduce employee time at the MFP, using the automatic document feeder.Confidently capture data. HP EveryPage lets you scan without worry and detect potential errors on the spot.Save time with automatic job sorting and finishing, using the 3-bin stapling mailbox.
HP LaserJet Enterprise MFP M680f - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English, German, French, Italian, Spanish / Europe
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
120000 pages
Recommended Monthly Volume
3000 - 17000 pages
Max Copying Speed
Up to 42 ppm (mono) / up to 42 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 43 ppm (mono) / up to 42 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi, 100 x 100 dpi
Scanning
600 dpi
Display
8"
Original Size
68 x 148 mm (min) - Legal (216 x 356 mm) (max)
Document Feeder Capacity
100 sheets
Media Size
101.6 x 152.4 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Standard Media Capacity
1100 sheets
Max Media Capacity
3100 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Office Machine Features
Document send function
AC 230 V (50Hz)
84 cm x 68.1 cm x 113.5 cm
77.9 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
120000 pages
3000 - 17000 pages
Display Diagonal Size
8"
Display Features
Touch screen
AirPrint Enabled
Max Supported Memory
2 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
9999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 5e, PCL 6, PDF
Image Enhancement Technology
HP ImageREt 4800, HP ProRes 1200
Automatic Duplexing
First Print Out Time B/W
18.5 sec
Scanning
Scan Element
CCD
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
PC Faxing
Yes (send only)
Fax Machine Features
Broadcast Transmission
100 stations
Document & Media Handling
Min Original Size
68 x 148 mm
Max Original Size
100 sheets
Min Media Size
101.6 x 152.4 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), JIS B6 (128 x 182 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm), 101.6 x 152.4 mm
1100 sheets
Max Media Capacity
3100 sheets
100 sheets
500 sheets
ADF - 100 sheets size: 68 x 148 mm - Legal (216 x 356 mm) , 2 x input tray - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Bypass tray - 100 sheets , Output tray - 500 sheets
Speed Details
Printing: up to 43 ppm (A4) - B/W normal , Printing: up to 42 ppm (A4) - colour normal , Printing: up to 45 ppm (Letter A) - B/W normal , Copying: up to 42 ppm (A4) - colour normal , Copying: up to 38 ipm (A4) - colour duplex , Copying: up to 40 ipm (Letter A) - B/W duplex , Copying: up to 40 ppm (Letter A) - colour duplex , Copying: up to 45 ppm (Letter A) - B/W normal , Scanning: up to 60 ppm (Letter A) - B/W normal , Scanning: up to 45 ppm (Letter A) - colour normal
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A
Security Protocols & Features
IPsec
Operating System Support
MS Windows 7, MS Windows XP SP3, MS Windows Vista, MS Windows Server 2008, Apple Mac OS X 10.6, MS Windows Server 2008 R2, Apple Mac OS X 10.7, HP-UX 10.20, Apple Mac OS X 10.8, MS Windows Server 2012, Windows 8, Apple Mac OS X 10.9
