| Quicklinx: | 5745WS00 |
| Mfr#: | CC435A#ABU |
Get advanced print, copy, fax, and scan capabilities in a single easy-to-use device, eliminating the expense and space of multiple single-function devices. Receive both black-and-white and color output quickly with print speeds of up to 21 pages per minute (ppm) on letter-size paper.Typical office print job Time To Completion can be nearly three times faster with the MFP's Instant-on Technology. Instant-on Copy with LED-based scanning technology delivers your first copy in seconds.With a total input capacity of up to 550 sheets, you can stay focused on your work. Use the 50-page automatic document feeder (ADF) for unattended copying, scanning, and faxing. Save time with built-in automatic two-sided printing and copying.The HP Color LaserJet CM2320fxi MFP's photo memory card slots make it simple to create impressive marketing materials with high-quality photo accents. Import images directly into business documents, or print them from the control panel.Print professional-quality brochures and more at your desk. Free HP marketing tools allow you to create and customize your documents instantly, so each communication speaks directly to your customers' needs. With the included Print View feature, you can change print settings and see immediately how those changes affect your document before you print. Determine costs beforehand for better project planning and decision-making with the Print Cost Estimator.Easily get optimized print quality for each of the many supported media types. With a single click in your print driver, select from a collection of pre-configured Printing Shortcuts - including settings for everyday printing, envelopes, glossy paper, and more.This MFP is not just easy to use - it's also easy to install, share, and maintain. Set-up wizards and installers help you get started. Original HP print cartridges are preinstalled and a handy front-access panel makes replacement effortless.Ideal for small work teams, the MFP offers networking performance. Manage your MFP with HP Easy Printer Care Software, a simple tool to deploy, monitor, and maintain up to 20 devices.
