Boost productivity in the office with the affordable and easy to manage HP Chromebox. Get easy access to data and effortless collaboration with your team using cloud based Google Apps for Business.
Free up your workspaces with the impressively small, contoured, and sleek design of the HP Chromebox. At just 126 mm x 124 mm x 39 mm (4.96 in. x 4.88 in. x 1.53 in.) it fits almost anywhere.
VESA versatility
Easily attach your HP Chromebox behind a display or secure it to any flat surface using the integrated VESA mount.
Performance and productivity in a compact footprint
Make the most of small work spaces with an optional HP IWC for your HP Chromebox. Combine a display with your HP Chromebox and get convenient front access to all of its inputs.
Quick set up and take down
Make mounting and securing storage your HP Chromebox easier with the HP Quick Release Mounting Bracket.
Easy to secure and manage
The HP Chromebox has security features you need to protect your data along with optional manageability features that help reduce downtime and free up time spent on user support.
Help secure critical data
The embedded Trusted Platform Module (TPM) provides hardware-based encryption to help secure your data and deter attacks from viruses and malware.
HP Chromebox - mini - Celeron 2955U 1.4 GHz - 2 GB - SSD 16 GB
