Make the move to a cloud-based infrastructure with the HP Chromebook 14. Get down to business with Intel Celeron processors, an optional Full HD IPS panel, Citrix -certified VDI compatibility, and access to Google Apps for Work.
Use your productivity apps, stream, and collaborate with a long battery life that can last.
Just what you need
Choose the Chromebook 14 that suits your work. Pick from configurations that vary by processor, memory, storage and type of display to find the right Chromebook 14 to help you meet the demands of your work.
Your HP Chromebook is just the beginning
Customize your Chromebook with the latest apps, tools, extensions, and themes, anytime, from the Chrome Web Store.
Storage wherever you go
Keep your important files accessible from an Internet connection with 100 GB of storage, for two years, on your own Google Drive Storage.
Seriously secure
Get virus protection at the operating system and browser level.
