With its powerful Intel Celeron processor and long-lasting battery, you’ll be perfectly equipped for both work and play with the HP Chromebook 11.
High quality and affordable, you can enjoy speedy loading, fast web browsing and HD graphics whether you’re using your Chromebook laptop at your office desk or on the move.
At just 1.28kg, this HP Chromebook is lightweight and easy to carry around, and measures 30cm x 20.57cm x 2.045cm so it’s compact enough to fit into your handbag or briefcase.
With up to 8.5 hours’ battery life, you can rest assured that you’ll be able to complete a full day’s work even if you’ve forgotten to pack your charger cable. Take advantage of speedy Wi-Fi technology and Bluetooth 4.0 for swift data transfer.
This model comes with 4GB installed memory and a display size of 11.6-inches.
Stay in control and minimise security risks with the embedded security chip and security lock slot – so only you have access to the data stored on your laptop.
