The HP Ultra Extended Life battery allow you to work longer indipendently from a power plug. The Ultra Extended Life battery provides the convenience of charging with an AC adapter plugged into the built-in Integrated AC Power Port when it is not in use. With the improved battery life, the battery is a great solution for anyone who requires maximum battery life for all-day computing.
