Back
Accessories
HP 45W USB-C G2 Power Adapter
Quicklinx:
F6ZFWS00
Mfr#:
1HE07AA#ABU
Back
Power and charge your notebook or tablet from its USB-C port with the HP 45W USB-C G2 Power Adapter.
Simple to use
Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet.
Easy to carry and store
Pack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it.
World-class support
Rest easy with a one-year limited warranty.
HP USB-C G2 - power adapter - 45 Watt
Power adapter - external
English / United Kingdom
Input Voltage
AC
Power Capacity
45 Watt
Input Connectors
24 pin USB-C
6.2 cm x 6.2 cm x 2.85 cm
1-year warranty
Input Voltage
AC
Input Connectors
24 pin USB-C
Power Capacity
45 Watt
Limited warranty - 1 year
6.2 cm
6.2 cm
2.85 cm
