Take on your work with the HP 280 MT desktop PC. Get the computing power you need for your business while minimizing the total cost of ownership-now that's a smart investment.
Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business.
Help secure critical data
The embedded Trusted Platform Module 1.2 (TPM) is field upgradeable to TPM 2.0 through a firmware upgrade which provides hardware-based encryption keys to help secure your data, e-mail, and user credentials.
Eight USB ports
Make connections to peripherals with eight USB ports on the HP 280 MT. Two front and four rear USB 2.0 ports are ready to connect to USB compatible peripherals, while two rear USB 3.0 ports are ready to charge your tablet or phone.
PC management made more manageable
Quickly get to the updates you need with HP Support Assistant.
Simple wireless printing
Make better use of your workspace. HP ePrint makes wireless printing simple, no need for drivers.
Valuable support at your service
Simplify technical support with Helpdesk by HP Care. Rely on cost-effective expertise that's available 24x7, covering multiple brands, devices, and operating systems.
Intel HD Graphics 510 Dynamic Video Memory Technology
Audio Output
Stereo
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Software Included
CyberLink Power2Go, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink PowerDVD BD Edition, Windows Defender, HP BIOS Configuration Utility (free download)
17 cm x 35.5 cm x 35.88 cm
6.11 kg
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
Micro tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Intel Pentium G4400
Clock Speed
3.3 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DVI
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Realtek RTL8111G-CG
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x internal 3.5"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 2.0 x1
6 x USB 2.0 (2 front, 4 rear) , 1 x headphones/microphone (1 in front) , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out , 1 x audio line-in , 1 x VGA , 1 x DVI-D
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
UL, FCC, WEEE, CECP, CEL, SEPA
Power supply
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Software
