HP Printer Compatibility = LJ P2035/P2055
100% Original HP quality.Now for up to 30% less. Original HP Economy toner cartridges
Benefits at-a-glance
- Get the high-quality toner your business needs, at a price adjusted to your budget
- Rely on cartridges designed to work seamlessly with your HP LaserJet printer or multifunction printer (MFP) to deliver consistent quality, cartridge after cartridge
- Get back to business quickly with toner cartridges that are easy to install and replace
- Take advantage of easy cartridge recycling through HP Planet Partners
Lower, upfront cost
Original HP Economy toner cartridges allow your business to consistently produce the sharp, black text and vivid colour documents you expect--tailored to fit your business budget. Printing is a closely managed expense for many businesses, and you can make the most of your budget by choosing reliable Original HP toner cartridges. Tests have shown that Original HP LaserJet toner cartridges worked the first time, every time.
The Economy toner cartridges have a lower yield, so you pay less per cartridge than you do for standard HP cartridges but get the same legendary quality and reliability only Original HP toner cartridges can offer. Original HP Economy toner cartridges offer the lowest cost per cartridge in the HP portfolio. HP also offers standard "A" and high-yield "X" cartridges as well as multi-packs for customers looking for a lower cost per page solution.
Precise, dependable results
Like all Original HP cartridges, Original HP Economy toner cartridges are specially designed and tested with your printer or MFP to produce optimal results. That means you can rely on consistent, professional-quality performance--page after page and cartridge after cartridge.
Recycling
Once you are finished using your Original HP Economy toner cartridge, you can return it through HP Planet Partners for easy recycling.2
Choose the HP cartridge that matches your printing needs and budget
- Economy cartridges--lowest priced cartridge
- Standard cartridges-- for general printing
- High-yield cartridges--great value
- Multi-packs--best cost per page
