The leading-edge thermal glass bending technique makes the 6.81-inch quad-curved screen possible, providing a splendid all-round experience to you. The combination of super streamlined body and smooth curves enables the phone to fit your hand perfectly.
Compared with the last generation, the frame is much slimmer both up and down for a larger display area.
