The WAE speaker has been specially designed for the community of Android users. Fun and trendy design, both modern and ergonomic. The speaker perfectly suits your Android's lifestyle! Excellent Bluetooth technology ensures incredible sound quality within a 10 meter range.
Â
Are you an Android fan? So are we! Enjoy the music stored on your Android smartphone with complete freedom. Easily air and share all the music stored on your smartphone. The BTP05's modern and ergonomic design ensures that it blends in seamlessly with your Android lifestyle.
WIRELESS The BTP05 offers the best of Bluetooth® wireless technology, delivering exceptional sound quality with a 10 metre range (33'). Carry it around your home, using its grip, and use it to take your music everywhere you go.
Battery life The BTP05 is powered by a battery offering 15 hours' playback at medium volume. Be sure that your speaker will follow you everywhere you go!
Crank it up Even when powered by its battery, the speaker delivers up to 30 W power. Whether at home or on the move, your speaker will be the ideal companion for every party.
AUX input The speaker features a 3.5 mm mini-jack input, enabling you to connect it to your MP3 player or any other music device.
The speaker's sound quality benefits from Hercules' extensive audio expertise. You will enjoy virtually no distortion, even at high volumes.
Play it loud and long
15 hours of playing time at medium volume is just amazing, considering the audio output power that the speaker delivers. The 2 full-range speaker drivers provide great frequency response, from 80 Hz to 20 kHz.
Hercules Wireless Audio Experience BTP05 - speaker - for portable use - wireless
Speaker - for portable use
Enclosure Design
Bass reflex
Speaker Type
2-way - active
Continuous Power
15 Watt
Frequency Response
80 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker Details
Speaker - stereo x 2 - 7.5 Watt - 80 - 20000 Hz - active
White
Speaker battery rechargeable
34 cm x 14 cm x 12 cm
Enclosure Colour
White
Enclosure Design
Bass reflex
Design Features
High gloss laquer finish
Speaker System
Speaker Type
2-way - active
Continuous Power
15 Watt
Frequency Response
80 - 20000 Hz
Amplifier
Integrated
Bluetooth 3.0
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Transmission Range
10 m
Controls
Power on/off, volume
Speaker System Details
Speaker Details
Speaker - stereo x 2 - 7.5 Watt - 80 - 20000 Hz CFR - active
