Back
Refinements
HannsG 21.5" Full HD 1080p 5ms Response Time HDMI & VGA
Quicklinx:
BYTSWS00
Mfr#:
HL225HNB
Back
Marketing description is not available.
HANNS.G HL225HNB - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class E
Energy Consumption per Year
23 kWh
Power Consumption (On mode)
16 W
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
700:1 / 40000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
Warm
51.28 cm x 18.42 cm x 36.74 cm
3.2 kg
CB, EU Energy Label
Display Type
Energy Class
Class E
23 kWh
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
WLED
HDCP
Warm
3.2 kg
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-3/+20
VESA Mounting Interface
100 x 100 mm
Earphone
1 x VGA cable - 1.5 m
CB, EU Energy Label
Security Slot Type
Kensington security slot
Input Voltage
16 W
16 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
5 °C
35 °C
20 - 85% (non-condensing)
