- Desktop booster for flexible working while sitting or standing
- Continuous height adjustment (18 - 43 cm)
- Gas spring for easy adjustment
- Quick, single-handed operation thanks to user-friendly handle for lifting and pushing downwards, ensuring ultra-simple height adjustment
- Incl. holder for tablet or smartphone
- Size of table top: 68.0 x 52.0 cm
- Size of keyboard plate: 68.0 x 21.5 cm
- Suitable monitor arms - 00095820, 00095826 & 00095827
Technical Details:
- Cable Guide: No
- Tilt angle (maximum): 55 °
- Depth keyboard tray: 68 cm
- Depth monitor tray: 68 cm
- Max. recommended load: 15 kg
- Max. recommended load keyboard: 2 kg
- Max. recommended load monitor: 15 kg
- Width keyboard tray: 21,5 cm
- Width monitor tray: 52 cm
- Width x Depth x Height: 52 x 68 x 18 cm
- Colour: Black
