With the Gyration Air Mouse GO Plus featuring MotionSense, the world just got easier to navigate. No strings, no wires, no tricks, no gimmicks - just better technology that allows you a more comfortable and versatile mouse to operate in the air or on the desk. Take control of your presentations, entertainment, and Internet browsing with natural hand movements. You'll wonder how you ever did it any other way.
Experience the patented MotionSense technology inside the Air Mouse GO Plus that delivers precise in-air cursor control and convenience. Ideal for any desktop computer user, the Air Mouse GO Plus features an ergonomic ambidextrous design that is easy to use. Use natural and comfortable wrist movements to take in-air control of your computer. Trigger activated MotionSense technology translates your hand movements into on-screen cursor motion for in-air operation.
Unleash yourself from the desktop. Interference free 2.4 GHz RF technology allows you to take mouse control from up to 100 feet away with no line of sight restrictions. Take total control with simple hand motions allowing you to skip music tracks or control volume in multimedia applications, highlight important points in presentations, and much more. The Gyration Air Mouse GO Plus features software with a wide range of programmable actions including freehand drawing, highlighter, zoom, Internet and Windows shortcuts, plus PowerPoint and presentation tools.
