Expand your computer’s capabilities
One small port doesn’t need to be one big problem. Expand your computer’s capabilities with the innovative Griffin Universal USB-C Docking Station. With four traditional USB-A ports, an HDMI port, USB-C port capable of delivering up to 85 watts of output power, LAN Ethernet and auxiliary ports, it means serious business. Connect to another monitor, setup a sound system for presentations, hardwire into your LAN Ethernet, charge multiple devices, or transfer data at reliably high speeds; is there anything it can’t do?
The Universal USB-C Docking Station includes an independent power supply, so you’re always ready and always on. It even makes organizing your cables a breeze, turning time wasted fumbling for the right one into time well spent. Finished with a clean, cool space gray aluminum housing, the Universal USB-C Docking Station seamlessly blends into every office environment.
- USB-C PD 2.0 output port provides up to 85W of power
- 4 USB-A 3.0 ports connect to multiple devices with high speed data transfer (one port supports fast charging)
- HDMI port lets you mirror your screen or simply extend it with up to 4K video resolution
- Hardwire into the Local Area Network with the dedicated Gigabit Ethernet port
- Audio jack connects to headphones, earbuds and most sound systems
- Premium aluminum housing
- 100W power adapter (20V/5A) and USB 3.0 Type-C cable included
