            Designed to meet or exceed US Department of Defense MIL-STD-810G, Survivor All-Terrain protects your iPad Pro from 8-foot (2.4-meter) drops onto concrete. Inside Survivor All-Terrain's hard shell, the proprietary Impact Dispersion System surrounds your iPad with a silicone ring that absorbs and directs impact forces away from the device.
You shouldn't have to sacrifice protection to get a slim, easy-to-use case for your iPad. Survivor All-Terrain has been redesigned to be thinner than the competitors' rugged cases. A recessed back and easy-to-grip bumper work together to make this Survivor All-Terrain easiest to hold yet.
Survivor All-Terrain's 4 layers of protection start with a shatter-resistant polycarbonate frame surrounded by a rugged, shock-absorbing bumper. The HD clarity screen protector snaps on to seal your touchscreen from the outside environment. Volume, power and mute switches are covered. And hinged plugs seal the dock connector and headphone port when you're not using them.
Survivor All-Terrain surrounds your iPad in protection, but never gets in your iPad's way. Water-proof speaker ports ensure that the speakers sound great. The screen shield is totally compatible with your iPad's Touch ID sensor, 3D Touch and even your Apple Pencil. And a fully-redesigned clip-on workstand is included; it's perfect for positioning your iPad for watching videos or typing. There's even a built-in holder for your Apple Pencil.
