            Transform HERO13 Black into the ultimate POV camera by capturing more in every shot with the highest level of video stabilisation. The premium HB-Series Ultra-Wide Lens Mod dramatically expands HERO13 Black’s field of view (FOV) to 177°—36% wider and 48% taller than shots captured with its standard lens.1 It also maximises HyperSmooth performance for unbreakable in-camera video stabilisation with resolution all the way up to 4K60. Recording in the new 1:1 aspect ratio gives you the freedom to crop your footage to widescreen 16:9 or vertical 9:16 shots. HERO13 Black detects the lens and automatically adjusts its settings accordingly—no other setup needed. Durable and scratch-resistant, the lens is completely waterproof2 when installed and ready to capture immersive shake-free footage of your adventures.
1 36% wider compared to HERO13 Black recording 16:9 aspect ratio footage with the Wide digital lens vs. HERO13 Black with the Ultra-Wide Lens Mod using the Ultra-Wide digital lens. 48% taller compared to HERO13 Black recording 9:16 aspect ratio footage with the Wide digital lens vs. HERO13 Black with the Ultra-Wide Lens Mod using the Ultra-Wide digital lens.
2 Ultra-Wide Lens Mod is not intended for use under water.
What’s Included
- Ultra-Wide Lens Mod
- Front and Rear Protective Caps
- Microfibre Lens Cloth
