| Quicklinx: | FMFLWS00 |
| Mfr#: | GA00760-UK |
Pixel's extraordinary camera, Google Assistant built in and a battery that lasts all day - everything is possible with Google Pixel 3a XL.
The camera that does the work for you.
Night Sight
Lose the flash, get the shot. Night Sight gives you rich detail and colour, even in the dark.
Depth editor
Focus on what matters by adjusting the depth of field.
Colour pop
Make the colour pop, while softening the background in black and white.
Unlimited Storage
Save your photos and videos with free, unlimited storage in high quality with Google Photos.
The power to do more
All-day battery.
Lasts up to 30 hours. Pixel’s Adaptive Battery learns your favourite apps and reduces power to those you rarely use.
Fast charging.
Enjoy up to 7 hours of use on a 15-minute charge with the 18 W adaptor included.
Google Assistant
Make Google do it.
Your Google Assistant can send texts, find answers, get commute times, set reminders and more.
The easiest way to get things done.
Do more with your Google Assistant. Just ask, or give your pixel a squeeze.
Peace of mind built in.
Secured with Titan M.
From passwords to the OS, Google’s custom-made Titan M security chip helps protect your most sensitive data.
3 years of updates.
Automatic security and OS updates will make sure that your phone is protected against the latest threats.
Specs
Operating system:
The latest Android 9.0 Pie. Minimum 3 years of OS updates.
Display:
Full-screen 6.0" display/152.4 mm display
FHD+ (2160 x 1080) OLED at 402 ppi
18:9
Always-on display
Now Playing
100,000:1 super contrast ratio
True black level
Full 24-bit depth or 16 million colours
D67 white point
Cameras:
Rear camera - 12.2 MP dual-pixel; 1.4 µm pixel width; Auto-focus with dual-pixel phase detection; Optical + electronic image stabilisation; ƒ/1.8 aperture; 76° field of view
Rear Camera Video - 1080p @ 30fps, 60fps, 120fps; 720p @ 30fps, 60fps, 240fps; 4K @ 30fps
Front camera - 8 MP; 1.12 µm pixel width; ƒ/2.0 aperture; Fixed focus; 84° field of view
Front Camera Video - 1080p @ 30fps; 720p @ 30fps; 480p @ 30fps
Processors:
Qualcomm® Snapdragon™ 670
2.0 GHz + 1.7 GHz, 64-bit Octa-Core
Adreno 615
Titan M security module
Memory and storage:
4 GB LPDDR4x RAM
64 GB storage
Battery:
3700 mAh battery
USB-C™ 18 W adaptor with USB-PD 2.0
18 W fast charging
Ports:
USB-C™ USB 2.0
Single nano SIM
3.5 mm audio jack
What's in the box:
Pixel 3a XL
18 W USB-C™ power adaptor
1 m USB-C to USB-C cable (USB 2.0)
Quick Start Guide
Quick Switch Adaptor
SIM tool
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots.
