Know more. Outside or in.
Who’s in the garden? What’s the dog up to? Nest Cam is battery powered, so it goes wherever you need it most, outside or in. It knows the difference between people, animals and vehicles, so you can get the alerts that are important to you. Listen and speak through the camera, right from the Google Home app. Check in anytime with 24/7 live view. If you miss a notification, it includes 3 hours of event video history so you can go back and see what happened. And it’s easy to install yourself – no outlet or wires required.
Check in on what matters.
Nest Cam shows you what’s happening at home, and alerts you of important activity, no matter where you are. It can tell the difference between a person, animal and a vehicle. And if you miss something, go back and see what happened with 3 hours of free event video history in the Google Home app.
Get alerts and take action.
Nest Cam helps you know that things are OK at home. If something happens, it alerts you, so you can decide to take action right from the Google Home app. You can also talk and listen from anywhere through the camera’s built-in microphone and speaker.
Outdoors or indoors. Rain or shine.
With no wires and a range of accessories, Nest Cam is designed to go anywhere. It’s battery powered and weather resistant. Put it on the exterior of your house to check in on the yard. Or put it inside your home to check in on the dog or your family. An available stand makes it easy to set up wherever you want (sold separately)
Protects your privacy.
Nest Cam uses encrypted video, two-step verification, and enhanced security through your Google Account to help protect your privacy. And a green LED light lets you know when the camera is processing or streaming video.
Home & Away Routines give you the option of automatically turning your camera off when you’re home, so no video is streamed or recorded until you leave.
See clearly in any light.
HDR helps you see key details in bright, high-contrast sunlight, and night vision gives you a clear image even in low light and darkness.
Go back in time.
If you miss a notification or other event, you can go back and see what happened with 3 hours of free event video history. And you can always add a Nest Aware subscription to get up to 60 days of video history. (Extra subscription required)
Choose the areas that matter most.
Activity Zones let you define specific areas and get notified when something happens there. So you only get alerted about things that are important to you.
Wi-Fi problems? Not a problem.
If your Wi-Fi goes down or there’s a power outage, Nest Cam will automatically store up to one hour of recorded events in its memory. When things are up and running again, you’ll be able to see exactly what happened.
Install it yourself.
Wire-free installation is easy. You can put Nest Cam almost anywhere you want, outside or in. And since it’s battery powered, you don’t need to install it near an outlet.
Better together.
Nest Cam works with Nest Hub to let you see your Nest Cam live feed on the Nest Hub display. You can also zoom in to get a closer look.
2 Year Warranty
