Bundle includes:
Google Home Mini Smart Speaker (GA00210-UK)
TP-Link LB110 E27 Kasa Smart Wi-Fi LED Bulb with Dimmable Light (includes Bayonet Adapter)
TP-Link HS100 Kasa Smart Wi-Fi Plug
Home Mini
Get hands-free help in any room with Google Home Mini. It's powered by the Google Assistant. You can ask it questions. Tell it to do things. It's your own personal Google. Use your voice to quickly find information about the weather, news, sports and more. Get help with things like your schedule, commute, travel information and more. Control your favorite music, movies and shows, using only your voice. Get personalized responses for everyone at home with voice recognition.
LB110 Smart Bulb
No Hub Required – Connect the bulb to your Wi-Fi at home
Manage Remotely – Easy setup and control from anywhere with the free Kasa app (iOS, Android)
Dimmable Light – Adjust brightness to suit your mood
Voice Control – Pair to Amazon Alexa and the Google Assistant to enable voice control
Monitor Power – Track real-time energy used to stay informed
Save Energy – Reduce energy use up to 80% without brightness or quality loss compared to a 60W incandescent bulb
Compatibility – Compatible with Android, iOS and Amazon Alexa and the Google Assistant
HS100 Smart Plug
Remote Access – Easy setup and control from anywhere with the free Kasa app (iOS, Android).
Scheduling – Schedule the Smart Plug to automatically power electronics on and off as needed, like setting lights to come on at dusk or turn off at sunrise.
Away Mode – Turns your devices on and off at different times to give the appearance that someone is home.
Voice Control – Pair to Amazon Alexa or The Google Assistant to enable voice control.
Grouping – Use Grouping to combine all 3 of your smart plugs on the power strip with other Kasa Smart devices for seamless control with one single tap on your smartphone.
Smart Actions – Enable device interconnections and home automation for your Kasa devices. There are three types of Actions that can be created: "Motion Sensing", "Schedule a Scene" and "Auto-off Timer".
