Gigabyte Z77-DS3H Motherboard combine a host of new and exciting technologies with the latest Intel Z77 Express Chipset, creating a unique range of motherboard designs that harness the outstanding performance of the new 3rd generation Intel Core processors. With an exclusive Gigabyte 3D BIOS (Dual UEFI), UD4 Classic technology and unique EZ Set Up uilities, Gigabyte Z77-DS3H Motherboard ensure outstanding system absolute control, with additional features that ensure an unrivalled experience on your next PC build.
- 3D Bios
- 3rd Generation Intel Core Processors support
- PCI-E 3.0 Support
- Intel Rapid Start Technology
- Gigabyte Ultra Durable 4 Classic
- Gigabyte EZ Smart Response
- Onboard mSATA
- Gigabyte 333 Onboard Acceleration
- Gigabyte On/Off Charge
- Lan Optimizer
- Multi-Display Support with CrossFireX
- 3 Years Manufacturers Warranty
- CPU: Support for Intel Core i7 processors/Intel Core i5 processors/ Intel Core i3 processors/Intel Pentium processors/Intel Celeron processors in the LGA1155 package, L3 cache varies with CPU
- Chipset: Intel Z77 Express Chipset
- Memory: 4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory, Dual channel memory architecture, Support for DDR3 2400(OC)/1600/1333/1066 MHz memory modules, Support for non-ECC memory modules, Support for Extreme Memory Profile (XMP) memory modules
- Onboard Graphics Integrated Graphics Processor: 1 x D-Sub port, 1 x DVI-D port, supporting a maximum resolution of 1920x1200, 1 x HDMI port, supporting a maximum resolution of 1920x1200
- Audio: Realtek ALC887 codec, High Definition Audio, 2/4/5.1/7.1-channel, Support for S/PDIF Out
- LAN: Atheros GbE LAN chip (10/100/1000 Mbit)
- Expansion Slots: 1 x PCI Express x16 slot, running at x16 (PCIEX16), 1 x PCI Express x16 slot, running at x4 (PCIEX4), 2 x PCI Express x1 slots, 2 x PCI slots
- Multi-Graphics Technology: Support for AMD CrossFireX technology
- Storage Interface Chipset: 2 x SATA 6Gb/s connectors (SATA3 0/1) supporting up to 2 SATA 6Gb/s devices, 3 x SATA 3Gb/s connectors (SATA2 2/3/4) supporting up to 3 SATA 3Gb/s devices, 1 x mSATA connector, Support for RAID 0, RAID 1, RAID 5, and RAID 10
- USB Chipset: Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header), Up to 8 USB 2.0/1.1 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
- Internal I/O Connectors: 1 x 24-pin ATX main power connector, 1 x 4-pin ATX 12V power connector, 2 x SATA 6Gb/s connectors, 3 x SATA 3Gb/s connectors, 1 x mSATA connector, 1 x CPU fan header, 3 x system fan headers, 1 x front panel header, 1 x front panel audio header, 1 x S/PDIF Out header, 2 x USB 2.0/1.1 headers, 1 x USB 3.0/2.0 header, 1 x Clear CMOS jumper, 1 x serial port header, 1 x Trusted Platform Module (TPM) header
- Back Panel Connectors: 1 x PS/2 keyboard/mouse port, 1 x D-Sub port, 1 x DVI-D port, 1 x HDMI port, 4 x USB 2.0/1.1 ports, 2 x USB 3.0/2.0 ports, 1 x RJ-45 port, 3 x audio jacks (Line In/Line Out/Microphone)
- I/O Controller: iTE I/O Controller Chip
- H/W Monitoring: System voltage detection, CPU/System temperature detection, CPU/System fan speed detection, CPU overheating warning, CPU/System fan fail warning, CPU/System fan speed control
- BIOS: 2 x 64 Mbit flash, Use of licensed AMI EFI BIOS, Support for DualBIOS, PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
- Warranty: 3 Years Manufacturers Warranty
