High accuracy laser engine offers consistent and reliable performance for absolute control and precise mouse movement. Equipped improved laser sensor, M6880X allows you to hit the target precisely.
3-Stage DPI adjustment
800/1200/1600 3-Stage DPI adjustable switch for quick on-the-fly DPI adjustment.
Anti-slick rubber grip with ideal shape for comfortable gameplay
Anti-slick ergonomic rubber grip and matt coating surface reduce wrist strain and maximize comfort during extended use.
Forward and backward buttons
Enjoy quickly browsing your favorite webpages or surfing throughout documents via the back and forward buttons which just located conveniently under your thumb.
Optimal lifting weight
Perfect weight offers ideal lifting weight and friction in the frenzy gameplay.
5 million clicks lifetime Omron switch
Ultra-durable 5 million clicks Omron switches not only extend the durability and also perfect the clicking response.
Gaming grade feet pads
Ultra-smooth Teflon gaming grade feet pads for improved accuracy and freedom of movement.
Gigabyte M6880X - mouse - USB - matte black
Mouse
Wired - USB
Matte black
Orientation
Right-handed
7.5 cm x 12.7 cm x 4.2 cm
100 g
Movement Detection Technology
Laser
Buttons Qty
5
Movement Resolution
1600 dpi
Performance
Realtime sensitivity switching 800/1200/1600 dpi, 125 reports per second, 6600 fps, 30 inches per second, 9 G maximum acceleration
Soft rubber grip, scrolling wheel, Teflon feet
Cable Length
1.5 m
Microsoft Windows Vista / XP / 7 / 8
Mouse
Orientation
Right-handed
7.5 cm
12.7 cm
4.2 cm
100 g
Matte black
Input Device
Wired
USB
Laser
Buttons Qty
5
Movement Resolution
1600 dpi
Performance
