Gigabyte 7 series motherboard takes advantage of the connectivity and expansion bus technologies on the Intel platform. The 3rd generation Intel Core processor platform debuts the PCI Express generation 3.0 expansion bus, allowing users to take advantage of the next generation, high-bandwidth discrete graphics card solutions.
Gigabyte 7 series motherboard features an onboard mSATA slot allowing users to easily take advantage of advanced SSD-based technologies like Intel Smart Response and Intel Rapid Start. Mounting an affordable, low capacity mSATA SSD directly onto your motherboard can enhance your PC's performance with better overall desktop responsiveness, faster boot times and faster system resume from 'suspend to disk' and 'standby' modes.
- Support for the new INTEL 3rd Generation CPU's. On the socket 1155 platform.
- USB 3x Power Boost. Delivering greater device compatibility and faster charge times.
- Ultra Durable 4 Classic. Advanced temprature, humidity, electrostatic and power failure protection... The ultimate in reliability.
- Super Speed USB 3.0. Super fast transfer rates of up to 5 Gbps, 10x faster than USB 2.0.
- DVI Monitor Connection. The standard for TFT computer monitors.
- Super SATA3 Native Suport. Supporting super fast 6Gbps link speeds.
- AMD Crossfirex. For multi display or ultimate performace gaming.
- PCIe GEN 3. Designed to take full advantage of the next generation high bandwidth graphic card solutions.
- UEFI DualBIOS™. A superior graphical BIOS interface, based on the trusted and secure GIGABYTE Dual BIOS technology.
- ON/OFF Charge Technology. Allows you to charge your iPad, iPhone or iPod even of your PC is off.
- Onboard mSATA Connector. Mount a low capcity mSATA SSD onto your motherboard to take advantage of INTEL SRT and RAPID START.
- HDMI Output. For the latest LCD monitors and HD TV's.
Tech Spec / H77-D3H
- CPU: Support for Intel Core i7, i5, i3, Pentium and Celeron 1155 processors(Go to GIGABYTE's website for the latest CPU support list.)
- Chipset: Intel H77 Express Chipset
- Memory: 4x DDR3 1600/1333/1066 MHz memory modules * Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
- Onboard Graphics: 1x D-Sub, 1x DVI-D (1920x1200 max res), 1x HDMI (1920x1200 max res)
- Audio: VIA VT2021 codec High Definition Audio 2/4/5.1/7.1-channel w/ Support for S/PDIF Out
- Multi-Graphics: Support for AMD CrossfireX
- LAN: 1 x Atheros GbE chip (10/100/1000 Mbit)
- Expansion Slots: 1 x PCI Express x16 slots, running at x16 / 1 x PCI Express x16 slots, running at x4 / 3x PCI Express x1 slot / 2x PCI slots
- Storage Interface: 2 x SATA 6Gb/s connectors / 4 x SATA 3Gb/s connectors / 1 x mSATA 3Gb/s (Disables sata connector 5 when in use)
- USB: USB 3.0/2.0 : 4x on the back panel, 2x via USB brackets on headers / USB 2.0/1.1 : 4x on the back panel, 6x via USB brackets on headers
- Internal I/O Connectors: 1 x 24-pin ATX main power connector, 1 x 4-pin ATX 12V power connector, 2 x SATA 6Gb/s connector, 4 x SATA 3GB/s connectors, 1 x mSATA connector, 1 x CPU fan header, 3 x system fan headers, 1 x front panel header, 1 x front panel audio header, 1 x S/PDIF Out header, 3 x USB 2.0/1.1 headers, 1 x USB 3.0/2.0 headers,1 x clearing CMOS jumper, 1 x TPM header, 1 x Serial port header
- Back Panel Connectors: 1 x PS/2 keyboard/mouse port, 1 x D-Sub, 1 x DVI-D, 1 x HDMI, 1 x Optical S/PDIF Out connector, 4 x USB 3.0/2.0 ports, 4 x USB 2.0/1.1 ports,1 x RJ-45 ports, 5x audio jacks
- BIOS: 2 x 64 Mbit AMI EFI BIOS, Support for DualBIOS™
- Form Factor: ATX Form Factor; 30.5 x 24.4cm
- Warranty: 3 Year Gigabyte Warranty
