- Powered by NVIDIA DLSS 3, ultra-efficient Ada Lovelace arch, and full ray tracing
- 4th Generation Tensor Cores: Up to 4X performance with DLSS 3 vs. brute-force rendering
- 3rd Generation RT Cores: Up to 2X ray tracing performance
- Powered by GeForce RTX™ 4080 SUPER
- Integrated with 16GB GDDR6X 256-bit memory interface
- WINDFORCE Cooling System
- RGB Fusion
- Dual BIOS
- Protection metal back plate
- Anti-sag bracket
- 4 Years Warranty (Online registration required)
The GIGABYTE GeForce RTX 4080 SUPER GAMING OC 16G features the GIGABYTE WINDFORCE cooling design, incorporating a 110 mm unique blade fan design, triple fan setup, and screen cooling to ensure optimal performance under heavy loads.
Equipped with NVIDIA GeForce RTX 4080 SUPER graphics processor and 10,240 CUDA cores, this video card delivers exceptional speed and power for gaming and creative work, supported by a 256-bit memory interface and 16 GB of GDDR6X SDRAM.
Leverage advanced gaming technology with NVIDIA DLSS 3, 3rd gen Ray Tracing Cores, and 4th gen Tensor Cores, enhancing your gaming experience with improved graphics and efficiency.
Features such as the durable VGA, reinforced backplate, and composite copper heat pipes ensure the longevity and durability of the video card, making it a reliable choice for gamers and professionals alike.
Support for DirectX 12 Ultimate and OpenGL 4.6, along with a maximum external resolution of 7680 x 4320, allows for stunning, high-definition visuals across multiple displays.
- Gigabyte GeForce RTX 4080 SUPER GAMING OC 16G - OC Edition - graphics card - NVIDIA GeForce RTX 4080 SUPER - 16 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Memory
- 16 GB GDDR6X
- Memory Speed
- 23 Gbps
- Core Clock
- 2595 MHz
- CUDA Cores
- 10240
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 3 x DisplayPort , HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 7.5 cm x 34.2 cm x 15 cm
- 4-year warranty with product registration
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Core Clock
- 2595 MHz
- CUDA Cores
- 10240
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, NVIDIA Ada Lovelace GPU technology, Triple Fan Design, NVIDIA DLSS 3, GIGABYTE WINDFORCE cooling design, RGB fusion, Dual Bios, reinforced backplate, NVIDIA RTX Video Super Resolution, Nvidia Studio, Nvidia Broadcast, NVIDIA Reflex, 110mm unique blade fan design, composite copper heat pipes, Gigabyte Alternate Spinning, GPU direct contact copper plates, large copper plate, 3D Active Fan, screen cooling, Graphene Nano Lubricant, Ultra Durable VGA
- Size
- 16 GB
- Technology
- GDDR6X SDRAM
- Memory Speed
- 23 Gbps
- Bus Width
- 256-bit
- Required Power Supply
- 850 W
- Additional Requirements
- 16 pin PCI Express power connector
- Included Accessories
- Anti-sag bracket, 16-pin to 3x 8-pin power adapter
- Software Included
- GeForce Game Ready Drivers, NVIDIA Studio drivers, Gigabyte Control Center
- DisplayPort 1.4a
- 7.5 cm
- 34.2 cm
- 15 cm
- Limited warranty - 3 years , Limited warranty - 4 years with product registration (within 30 days of purchase)
