            The airflow is spilt through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence.
When the GPU is under a set loading or temperature, the fans will remain off, creating an absolutely silent environment for gamers.
GIGABYTE Flex display technology can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. It reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability.
