Powered by NVIDIA GeForce GTX 960 GPU
Integrated with industry's best 2GB GDDR5 memory 128-bit memory interface
BASE: 1165 MHz / BOOST: 1228 MHz(1190/1253 MHz in OC Mode)
Features Dual-link DVI-I / Dual-link DVI-D / HDMI / DisplayPort
System power supply requirement: 400W (with one 6-pin external power connectors)
Ideal Cooling - 90mm Large Fansink
- Packed with GIGABYTE's unique blade fan design and pure copper heat pipe direct touch (HDT) technology, delivering superior cooling capacity and heat transfer efficiency at an extremely low noise level.
- Optimized fan speed according to real-time GPU temperature, effectively improving power efficiency.
- Measuring merely 17cm in length, the card, perfectly compatible for building most of the PCs from ATX to mini-ITX.
Ideal Durability - UDV
- Better overclocking performance by reducing voltage ripples in normal and transient state
- Lower temperature by doubling the copper inner layer of PCB and improving heat transfer efficiency
- Less power loss by stabilizing the electric current and reducing electrical impedance
OC GURU ll
Brand-new intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance, and OSD setting can be monitored and tuned in real-time according to your own preference.
