Gigabyte introduces Windforce, the latest cooling technology that differentiates the brand's graphics cards from the rest. Gigabyte understands that a fan is crucial to the graphics card, so only the fan with the most efficiency is selected for Windforce.
The airflow is spilt through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence.
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. Dual HDMI design lets users experience broader, richer gaming environments with better resolution on a single card.
Intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance, and OSD setting can be monitored and tuned in real-time according to your own preference.
