GV-N750OC-1GI
- Ultra Durable 2 Series
- Powered by NVIDIA GeForce GTX 750 GPU
- Integrated with the first 1024MB GDDR5 memory and 128-bit memory interface
- OC Edition : Base 1059MHz/Boost 1137MHz
- Features Dual-link DVI-I / DVI-D / HDMI*2
- Support PCI Express 3.0 x16 bus interface
- System power supply requirement: 400W
- Chipset GeForce GTX 750
- Memory Clock 5000 MHz
- Process Technology 28 nm
- Memory Size 1024MB GDDR5
- Memory Bus 128-bit
- Core Clock Base:1059MHz/Boost:1137MHz (Standard- Base:1020MHz Boost:1085MHz)
- Card Bus PCI Express 3.0
- DirectX 11.2
- OpenGL 4.4
- PCB Form ATX
- Digital max resolution 4096 X 2160 (via 2 HDMI)
- Analog max resolution 2048 x 1536
- Multi-view 4
- I/O Dual-link DVI-I1/DVI-D1/HDMI*2
- Card size L=185mm, W=135mm, H=42mm
- Power requirement 400W
Current graphic cards do not support HDMI specification, it is required to use two HDMI output to support Ultra HD resolution - 4096 x 2160 at 60 Hz. With a monitor features HDMI dual mode, users can experience an impressive 4K HD enjoyment with the latest technological advancements!
As opposed to the stereotype, Gigabyte is able to maximize fan size to 10 cm with the latest cooling design. With a 10 cm fan, the card is virtually silent that its noise level runs much lower.
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
Users can set up monitoring, GPU clock, memory clock, fan, OSD, online support and update driver, BIOS directly.
- Gigabyte GV-N750OC-1GI - graphics card - GF GTX 750 - 1 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 750
- Memory
- 1 GB GDDR5
- Core Clock
- 1059 MHz
- Boost Clock
- 1137 MHz
- Effective Memory Clock
- 5 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , DVI-D (dual link) , 2 x HDMI
- API Supported
- DirectX 11.2, OpenGL 4.4
- 4.2 cm x 18.5 cm x 13.5 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1059 MHz
- Boost Clock
- 1137 MHz
- 28 nm
- Max Resolution
- 4
- API Supported
- Nvidia PhysX-Ready, Ultra Durable 2, Nvidia 3D Vision technology, GIGABYTE custom-designed 100 mm cooler, Gold plated HDMI, Adaptive V-Sync, NVIDIA GPU Boost, OC Guru II
- Size
- 1 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 5 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 400 W
- Software Included
- OC Guru ll
- 4.2 cm
- 18.5 cm
- 13.5 cm
