- Boost clock OC to 1058MHz
- Up to 4 Displays on a single GPU
- GIGABYTE WINDFORCE™ 3X cooling design (with "Triangle Cool" technology)
- 10% Performance better than  GeForce GTX 670
- 50% Performance better than GeForce GTX 580
- 60% Performance better than GeForce GTX 570
- 9% Performance better than Radeon HD 7970
- 30% Performance better than Radeon HD 7950
- CUDA Core:  1344 / TSMC 28nm Process GPU
- Memory Amount: 2048MB
- Microsoft DirectX 11 and OpenGL 4.2 support
- NVIDIA® PhysX® technology / 3D Vision®-Ready
- Features Dual-link DVI-I / DVI-D / DisplayPort / HDMI
- 550 Watt or greater power supply recommended
Specification
- Model name   	GV-N670OC-2GD
- Core Clock   (MHz)	Base: 980MHz  Boost: 1058MHz
- Stream   Processor	1344
- Mem Clock    (MHz)	6008MHz
- Mem Size 	2048MB
- Mem Bus  (bit)	256 bit
- Mem Type 	64Mx32 GDDR5
- I/O  	Dual link DVI-I / DV-D	HDMI x1	Displayport
- DirectX  OpenGL	DirectX 11	OpenGL 4.2
- Card Interface   	PCI Express 3.0
- Board    Form	ATX	2 slot
- Accessory    	Power cable x2
- Fan/Heat Sink    	WINDFORCE 3X	with "Trangle Cool"
- System PSU Limitation    	550W
- Card Size    	H=43,L=285, W=136.6 mm
                Ultra durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. Gigabyte ultra durable VGA can lower GPU temperature by 5% to 10%.
                Ultra durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. Gigabyte ultra durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
                Ultra durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. Gigabyte ultra durable VGA can lower power switching loss by 10% to 30%.
                Gigabyte introduces the excellent "Triangle Cool" technology to reach a better cooling performance. The patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" technology provides a more efficient air flow for the cooling system.
                NVIDIA PhysX is a big thing in gaming! Delivering physics in games is no easy task. It's an extremely compute-intensive environment based on a unique set of physics algorithms that require tremendous amounts of simultaneous mathematical and logical calculations. The best way to get real-time physics, such as explosions that cause dust and debris, characters with life-like motion or cloth that drapes and tears naturally is with an NVIDIA PhysX-ready GeForce processor.
                NVIDIA CUDA technology unlocks the power of the cores in your NVIDIA GeForce graphics processor (GPU) to accelerate some of the most performance hungry computing applications.
                Delivers up to 2x the performance of a single GPU configuration for unparalleled gaming experiences by allows two graphics cards to run in parallel. The must-have feature for performance PCI express graphics, SLI dramatically scales performance on 60 top PC games.
                NVIDIA 3D Vision brings a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Users can even watch 3D movies and 3D digital photographs in crystal-clear quality.
                As a citizen of the global village, Gigabyte exerts you to be a pioneer in environment care. Give the whole of Earth a promise that the products do not contain any of the restricted substances in concentrations and applications banned by the RoHS directive, and is capable of being worked on at the higher temperatures required for lead free solder.
- Graphics Processor Manufacturer
- NVIDIA
- NVIDIA GeForce GTX 670
- Interface
- PCI Express 3.0 x16
- Memory Size
- 2 GB
- Digital Output
- Digital Visual Interface (DVI), DisplayPort, High-Definition Multimedia Interface (HDMI)
- Core Clock
- 915 MHz
