Gigabyte offers the exclusive WINDFORCE 2x 100 mm fansink equipped with
"Triangle Cool" technology to reach a better cooling performance. The patent
pending technology combines fin with clip module in a special triangle
shape. With the original anti-turbulence structure plus the triangle cooling
design, it enhances the efficiency of heat dissipation dramatically by
minimizing the flow of turbulence between fans.
The instinctive user interface, easier to monitoring and adjusting all
important settings. Users can set up monitoring, GPU clock, memory clock,
fan, GPU voltage, memory voltage, OSD, online support and update driver,
BIOS directly.
