The WINDFORCE 3X cooling system features 3 pure copper composite heat-pipes, special fin architecture, unique blade fan design, together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
The airflow is spilled by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans.
The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming.
